  • 2 Vote(s) - 3.5 Average
37-116 Restoration
#43
AFC (Magnetic Tuning) Won't work and I'm a bit confused. What/were (physically) is switch part #135?...
I'm almost done, except the magnetic tuning doesn't work. The IF alignment seemed to go well, things peaked, etc.. The tube voltages look sane. My suspicion is centered around the switch, part #93.
- When OFF points "A" and "B" measure grounded - GOOD.
- When ON  points "A" and "B" have a ~2ohm resistance between them - BAD - I think.
But, before I go and fool with the Magnetic Tuning switch (93), I need to figure out what the switch below it, part 135 (or so it says) is supposed to be.
Switch 135 seems to be able to connect points "A" and "B". So, maybe why I see the ~2 ohms (seems a bit high)?
What doesn't make sense is that Ride's lists part 135 as "Pilot Lamp (Codes 121-122). I don't think so.
The text below the arrow at the bottom of the schematic says "USED IN CODE 122 ONLY" (chopped it off).
Greg O.
Whitehall, PA
37-116 Restoration - by Greg - 02-08-2020, 12:26 AM
RE: 37-116 Restoration - by truePhilco - 02-08-2020, 09:00 AM
RE: 37-116 Restoration - by Jake Blake - 02-08-2020, 09:39 AM
RE: 37-116 Restoration - by truePhilco - 02-08-2020, 10:17 AM
RE: 37-116 Restoration - by Radioroslyn - 02-08-2020, 12:34 PM
RE: 37-116 Restoration - by Phlogiston - 02-08-2020, 12:45 PM
RE: 37-116 Restoration - by Greg - 03-02-2020, 06:13 PM
RE: 37-116 Restoration - by Radioroslyn - 03-02-2020, 06:58 PM
RE: 37-116 Restoration - by rfeenstra - 03-02-2020, 07:54 PM
RE: 37-116 Restoration - by Greg - 03-02-2020, 08:39 PM
RE: 37-116 Restoration - by rfeenstra - 03-03-2020, 12:11 AM
RE: 37-116 Restoration - by Greg - 03-21-2020, 12:31 PM
RE: 37-116 Restoration - by rfeenstra - 03-21-2020, 07:13 PM
RE: 37-116 Restoration - by Greg - 03-28-2020, 12:23 PM
RE: 37-116 Restoration - by rfeenstra - 03-28-2020, 01:24 PM
RE: 37-116 Restoration - by Greg - 05-13-2020, 11:00 PM
RE: 37-116 Restoration - by 462ron - 05-14-2020, 08:35 AM
RE: 37-116 Restoration - by morzh - 05-14-2020, 10:20 AM
RE: 37-116 Restoration - by 462ron - 05-15-2020, 07:13 AM
RE: 37-116 Restoration - by Radioroslyn - 05-15-2020, 09:35 AM
RE: 37-116 Restoration - by morzh - 05-15-2020, 01:08 PM
RE: 37-116 Restoration - by Greg - 07-21-2020, 10:04 PM
RE: 37-116 Restoration - by Greg - 08-02-2020, 12:20 PM
RE: 37-116 Restoration - by Phlogiston - 08-02-2020, 02:38 PM
RE: 37-116 Restoration - by Greg - 08-14-2020, 06:37 PM
RE: 37-116 Restoration - by Greg - 08-16-2020, 09:46 PM
RE: 37-116 Restoration - by Nathan Slingerland - 08-16-2020, 10:03 PM
RE: 37-116 Restoration - by Greg - 08-16-2020, 10:44 PM
RE: 37-116 Restoration - by rfeenstra - 08-17-2020, 12:24 AM
RE: 37-116 Restoration - by Nathan Slingerland - 08-17-2020, 12:42 AM
RE: 37-116 Restoration - by rfeenstra - 08-17-2020, 01:43 AM
RE: 37-116 Restoration - by Greg - 09-12-2020, 07:42 PM
RE: 37-116 Restoration - by Greg - 10-25-2020, 08:39 PM
RE: 37-116 Restoration - by rfeenstra - 10-26-2020, 12:14 AM
RE: 37-116 Restoration - by morzh - 10-26-2020, 11:28 AM
RE: 37-116 Restoration - by Radioroslyn - 10-26-2020, 11:43 AM
RE: 37-116 Restoration - by KCMike - 10-26-2020, 02:11 PM
RE: 37-116 Restoration - by Greg - 04-04-2021, 07:57 PM
RE: 37-116 Restoration - by Greg - 04-05-2021, 09:19 PM
RE: 37-116 Restoration - by rfeenstra - 04-05-2021, 11:43 PM
RE: 37-116 Restoration - by Greg - 04-06-2021, 08:38 PM
RE: 37-116 Restoration - by rfeenstra - 04-06-2021, 10:37 PM
RE: 37-116 Restoration - by Greg - 08-07-2021, 01:10 PM
RE: 37-116 Restoration - by Phlogiston - 08-07-2021, 01:45 PM
RE: 37-116 Restoration - by Phlogiston - 08-07-2021, 01:48 PM
RE: 37-116 Restoration - by morzh - 08-07-2021, 02:32 PM
RE: 37-116 Restoration - by Greg - 08-07-2021, 03:46 PM
RE: 37-116 Restoration - by Greg - 08-07-2021, 04:23 PM
RE: 37-116 Restoration - by Greg - 08-22-2021, 04:48 PM
RE: 37-116 Restoration - by mikethedruid - 08-22-2021, 06:00 PM
RE: 37-116 Restoration - by Greg - 02-28-2022, 12:04 AM
RE: 37-116 Restoration - by mikethedruid - 02-28-2022, 02:18 AM
RE: 37-116 Restoration - by Greg - 02-28-2022, 08:44 PM
RE: 37-116 Restoration - by Paul Philco322 - 02-28-2022, 08:56 PM
RE: 37-116 Restoration - by GarySP - 02-28-2022, 11:10 PM
RE: 37-116 Restoration - by mikethedruid - 02-28-2022, 11:35 PM
RE: 37-116 Restoration - by PhilcoJohn - 03-01-2022, 07:19 AM
Users browsing this thread: 41 Guest(s)
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
My new nostalgic video... My weekly video on radio history Who is interested - come, watch, critically evaluate the qu...RadioSvit — 01:47 PM
There are currently 3098 online users. [Complete List]
» 1 Member(s) | 3097 Guest(s)
