Philco 38-14 dial cover removal
How are the steel clips that hold the speaker grille and plastic dial cover removed in a Philco 38-14 cabinet without breaking the bakelite studs?
Thanks!
Chuck Owens
Philco 38-14 dial cover removal - by CEO - 08-07-2021, 09:19 PM
