Need help to fix my unintentional mistake.
First things first ....
That radio top is sprayed with a lacquer. The lacquer is toned (coloured) to what you see. The wood itself is NOT stained. The way to match it exactly is to spray the affected area with a toned lacquer using an airbrush or similar small sprayer. You'll have to blend the edges by slightly over-spraying and sanding to a finish.
Some people are able to mix the toned lacquer and wipe it on, so that may be another choice. Whatever you do, do NOT attempt to color the bare wood.
RE: Need help to fix my unintentional mistake. - by John Bartley - 08-08-2021, 05:13 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8180 online users. [Complete List]
» 2 Member(s) | 8178 Guest(s)
