Magnavox 1FM031
It probably needs new electrolytic capacitors, especially in the FM section, and then possibly an alignment.
Impressive radio. I've seen pictures of those before but I did not know they were that large.
Magnavox 1FM031 - by Paul Philco322 - 08-14-2021, 09:01 PM
RE: Magnavox 1FM031 - by Ron Ramirez - 08-15-2021, 12:12 PM
RE: Magnavox 1FM031 - by Paul Philco322 - 08-15-2021, 01:31 PM
RE: Magnavox 1FM031 - by Ron Ramirez - 08-15-2021, 01:38 PM
RE: Magnavox 1FM031 - by Eliot Ness - 08-16-2021, 08:53 AM
RE: Magnavox 1FM031 - by Ron Ramirez - 08-16-2021, 10:21 AM
RE: Magnavox 1FM031 - by Paul Philco322 - 08-26-2021, 04:22 PM
