Air King Tiny Bakelite Receiver
On the heater situation using a non polarized capacitor to replace the series resistor works well. No heat but sometimes size can be an issue. https://www.vintage-radio.com/repair-res...calcs.html
Air King Tiny Bakelite Receiver - by Antipodal - 08-17-2021, 10:05 PM
RE: Air King Tiny Bakelite Receiver - by RodB - 08-18-2021, 10:08 AM
RE: Air King Tiny Bakelite Receiver - by Radioroslyn - 08-18-2021, 10:57 AM
Eico 232 VTVM Schematic
There are currently 6468 online users. [Complete List]
» 2 Member(s) | 6466 Guest(s)
