Magnavox Provincial
I don't know at which point Mag switched from Webster-Chicago to Collaro, but if you have the rocker cartridge in the pickup arm, it sounds like the W-C 256. The pickup arms on those had the nme Magnavox molded in the arm.
If you could get some pictures in here, it would grease the skids for us.
Magnavox Provincial - by PFJC2 - 02-22-2011, 07:45 PM
Re: Magnavox Provincial - by Ron Ramirez - 02-22-2011, 09:59 PM
Re: Magnavox Provincial - by PFJC2 - 02-23-2011, 12:28 AM
Re: Magnavox Provincial - by Ron Ramirez - 02-23-2011, 10:14 AM
Re: Magnavox Provincial - by Doug Houston - 04-17-2011, 12:03 AM
Re: Magnavox Provincial - by PFJC2 - 04-17-2011, 09:15 PM
Re: Magnavox Provincial - by Ron Ramirez - 04-18-2011, 05:43 AM
Re: Magnavox Provincial - by Doug Houston - 04-18-2011, 05:32 PM
Re: Magnavox Provincial - by PFJC2 - 04-20-2011, 04:16 PM
Eico 232 VTVM Schematic
There are currently 9664 online users. [Complete List]
» 1 Member(s) | 9663 Guest(s)
