Philco C-1608 Issues
You won't find anything exactly the same. You have a few options, though. You can use a 10+10 can cap (it will be a lot smaller than the original, so you would need to make a sleeve to hold it in) or you can go with a 4.7uf and a 10uf individual caps under the chassis. The values are not critical, other than you don't want to go crazy high on them.
Philco C-1608 Issues - by Keefer - 08-24-2021, 01:56 AM
RE: 4uf/8uf gin can capacitor - by BrendaAnnD - 08-24-2021, 05:14 AM
RE: 4uf/8uf gin can capacitor - by mikethedruid - 08-24-2021, 05:29 AM
RE: 4uf/8uf gin can capacitor - by Phlogiston - 08-24-2021, 10:13 AM
RE: 4uf/8uf gin can capacitor - by Keefer - 08-24-2021, 11:17 AM
RE: 4uf/8uf gin can capacitor - by Phlogiston - 08-24-2021, 12:03 PM
RE: 4uf/8uf gin can capacitor - by mikethedruid - 08-24-2021, 01:20 PM
RE: 4uf/8uf gin can capacitor - by Keefer - 08-24-2021, 01:52 PM
RE: 4uf/8uf gin can capacitor - by mikethedruid - 08-24-2021, 02:02 PM
RE: 4uf/8uf gin can capacitor - by Keefer - 08-24-2021, 07:16 PM
RE: 4uf/8uf gin can capacitor - by Keefer - 08-24-2021, 07:21 PM
RE: 4uf/8uf gin can capacitor - by mikethedruid - 08-24-2021, 10:02 PM
RE: 4uf/8uf gin can capacitor - by John Bartley - 08-25-2021, 07:41 AM
RE: 4uf/8uf gin can capacitor - by Keefer - 08-25-2021, 09:01 AM
RE: 4uf/8uf gin can capacitor - by Keefer - 08-25-2021, 09:33 AM
RE: 4uf/8uf gin can capacitor - by David - 08-25-2021, 09:51 AM
RE: 4uf/8uf gin can capacitor - by Phlogiston - 08-25-2021, 10:36 AM
RE: 4uf/8uf gin can capacitor - by mikethedruid - 08-25-2021, 02:50 PM
RE: 4uf/8uf gin can capacitor - by Chas - 08-25-2021, 06:55 PM
RE: 4uf/8uf gin can capacitor - by Keefer - 08-26-2021, 01:41 PM
RE: 4uf/8uf gin can capacitor - by Keefer - 09-14-2022, 10:01 PM
RE: Philco C-1608 Issues - by admin - 09-15-2022, 08:00 PM
RE: Philco C-1608 Issues - by Keefer - 09-16-2022, 09:57 AM
RE: Philco C-1608 Issues - by David - 09-16-2022, 01:04 PM
RE: Philco C-1608 Issues - by fenbach - 09-16-2022, 11:36 PM
RE: Philco C-1608 Issues - by fenbach - 09-17-2022, 07:36 PM
RE: Philco C-1608 Issues - by Keefer - 09-18-2022, 09:05 AM
RE: Philco C-1608 Issues - by fenbach - 09-18-2022, 02:52 PM
RE: Philco C-1608 Issues - by Keefer - 09-21-2022, 11:19 AM
RE: Philco C-1608 Issues - by fenbach - 09-21-2022, 07:58 PM
RE: Philco C-1608 Issues - by Keefer - 09-21-2022, 08:01 PM
RE: Philco C-1608 Issues - by Keefer - 09-21-2022, 08:02 PM
RE: Philco C-1608 Issues - by Keefer - 09-21-2022, 08:04 PM
RE: Philco C-1608 Issues - by fenbach - 09-21-2022, 11:32 PM
RE: Philco C-1608 Issues - by Keefer - 09-22-2022, 03:42 PM
RE: Philco C-1608 Issues - by fenbach - 09-22-2022, 07:48 PM
RE: Philco C-1608 Issues - by Keefer - 09-22-2022, 08:00 PM
RE: Philco C-1608 Issues - by Keefer - 09-24-2022, 09:16 AM
RE: Philco C-1608 Issues - by Chas - 09-24-2022, 10:03 AM
RE: Philco C-1608 Issues - by MrFixr55 - 09-24-2022, 07:16 PM
RE: Philco C-1608 Issues - by fenbach - 09-24-2022, 07:22 PM
RE: Philco C-1608 Issues - by Keefer - 09-24-2022, 08:07 PM
RE: Philco C-1608 Issues - by MrFixr55 - 09-24-2022, 08:09 PM
RE: Philco C-1608 Issues - by Keefer - 09-25-2022, 05:14 PM
RE: Philco C-1608 Issues - by fenbach - 09-26-2022, 01:07 AM
RE: Philco C-1608 Issues - by Keefer - 09-26-2022, 09:21 AM
RE: Philco C-1608 Issues - by Keefer - 09-26-2022, 09:24 AM
RE: Philco C-1608 Issues - by Keefer - 09-26-2022, 10:03 AM
RE: Philco C-1608 Issues - by Keefer - 09-26-2022, 10:12 AM
RE: Philco C-1608 Issues - by fenbach - 09-26-2022, 09:37 PM
RE: Philco C-1608 Issues - by Keefer - 09-26-2022, 10:14 PM
RE: Philco C-1608 Issues - by Keefer - 09-29-2022, 07:40 PM
RE: Philco C-1608 Issues - by fenbach - 10-01-2022, 12:02 AM
RE: Philco C-1608 Issues - by MrFixr55 - 10-01-2022, 02:03 PM
RE: Philco C-1608 Issues - by Keefer - 10-05-2022, 06:08 PM
RE: Philco C-1608 Issues - by MrFixr55 - 10-05-2022, 10:20 PM
RE: Philco C-1608 Issues - by Keefer - 10-08-2022, 11:18 AM
RE: Philco C-1608 Issues - by fenbach - 10-08-2022, 11:50 PM
RE: Philco C-1608 Issues - by Keefer - 10-13-2022, 07:06 PM
RE: Philco C-1608 Issues - by Keefer - 11-24-2022, 04:00 PM
RE: Philco C-1608 Issues - by fenbach - 11-25-2022, 06:44 PM
Solid state vibrator - by Keefer - 09-15-2022, 01:51 PM
RE: Solid state vibrator - by David - 09-15-2022, 02:37 PM
RE: Solid state vibrator - by fenbach - 09-15-2022, 07:27 PM
