Too much noise between stations!
Is it just more sensitive? With a good AGC and a lot of dynamic range, plus RF amplification, it might just be bringing the interstation noise up higher?
What antenna are you using?
Too much noise between stations! - by murf - 08-25-2021, 01:46 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 03:03 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 03:09 PM
RE: Too much noise between stations! - by EdHolland - 08-25-2021, 03:58 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 07:58 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 09:51 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 09:53 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 10:00 PM
462ron - by 462ron - 08-26-2021, 07:58 AM
RE: Too much noise between stations! - by RodB - 08-26-2021, 10:23 AM
RE: Too much noise between stations! - by murf - 08-26-2021, 10:31 AM
RE: Too much noise between stations! - by murf - 08-26-2021, 11:05 AM
Eico 232 VTVM Schematic
There are currently 3184 online users. [Complete List]
» 2 Member(s) | 3182 Guest(s)
