Too much noise between stations!
The others are in my display room and plugged into the same power strip.
Definitely something with the radio.
Can try moving it to another room?
Murf
Too much noise between stations! - by murf - 08-25-2021, 01:46 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 03:03 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 03:09 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 07:58 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 09:51 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 09:53 PM
RE: Too much noise between stations! - by murf - 08-25-2021, 10:00 PM
462ron - by 462ron - 08-26-2021, 07:58 AM
RE: Too much noise between stations! - by RodB - 08-26-2021, 10:23 AM
RE: Too much noise between stations! - by murf - 08-26-2021, 10:31 AM
RE: Too much noise between stations! - by murf - 08-26-2021, 11:05 AM
Eico 232 VTVM Schematic
There are currently 9032 online users. [Complete List]
» 1 Member(s) | 9031 Guest(s)
