advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW)
Clean it, using DeoxIT. This should make your switch work properly.
Don't use the cheap contact cleaners, which may or may not work. If DeoxIT doesn't clean that switch, nothing will.
Spray the contacts with DeoxIT, then turn the switch back and forth several times to allow the DeoxIT to work into the contacts well. Then, let the residue evaporate before you apply power again. DeoxIT evaporates more slowly than some contact cleaners, so allow plenty of time for that and be patient.
Re: advice needed bringing this 47-1230 to its former glory - by Ron Ramirez - 04-18-2011, 05:38 AM
Philco 91 Tuning Condenser
There are currently 5988 online users. [Complete List]
» 2 Member(s) | 5986 Guest(s)
