advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW)
Thanks for the tip, Ron.
I am trying to locate a good supplier of deOxit in Canada, and notice there's a lot of different products. Some are spray, some are neddle application, some are brush-on.
Also, there's some 5% deOxit, and some 100%.
I am looking at the mini-aerosole 5% can for its narrow fitting that would make it easier to spray in the pots and switches, but should I be trying to get something else?
-Mars
Re: advice needed bringing this 47-1230 to its former glory - by Marsupial - 04-18-2011, 08:04 AM
There are currently 10145 online users. [Complete List]
» 3 Member(s) | 10142 Guest(s)
