Philco 49-1600 Speaker Stopped Working
Well that's good but it means that we need to dig in a bit further to see what the problem is. To do this you'll need a volt/ohm meter. A cheap one hf is fine, they use to give them away if you bought something at their store. Remove the plug from the wall socket and the knobs from the front by pulling them straight out by hand. Remove the screws that hold the chassis to the to the cabinet. Usually on the bottom of the chassis. Now is a good time to take a couple of pics. Unplug the phono from the chassis. Remove the chassis and take a few pics of the top and bottom. Just what to see what service work has been on it since 1949... Then the we'll get down to business.
I'm unsure as to how familiar you are any sort of electronic servicing. And what skills you have along these lines.
Here's the service info from Philco for your set: https://philcoradio.com/library/download...8-1949.pdf
RE: Philco 49-1600 Speaker Stopped Working - by Radioroslyn - 09-04-2021, 07:01 PM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
