advice needed: restoring 47-1230 - FM & AM now works!!!! :D (uncertain about SW)
I use DeoxIT D5 in the aerosol can.
Once I finished rebuilding a 41-226 "Sled," I tried using contact cleaner on the pushbutton mechanism. The pushbuttons still refused to work correctly after cleaning with the generic contact cleaner. So, I sprayed them with DeoxIT D5, and that's all it took...the DeoxIT restored the pushbutton mechanism to proper operation.
Read about the 41-226 here:
https://www.philcoradio.com/phorum/showt...?tid=14923
7estatdef Wrote:I'll point out that you need to be sure that all of the DeOxit is dry before you apply power.
Yup. Allow the DeoxIT to evaporate before applying power = let it dry before applying power = same thing.
Re: advice needed bringing this 47-1230 to its former glory - by Ron Ramirez - 04-18-2011, 06:48 PM
Philco 91 Tuning Condenser
