SOLVED Westinghouse RC radio-so... they think im the guy to get this thing working
Russ.
What model horn speaker is that in the early photo?
Does not look like a UZ-1325 nor an FH... chas
Pliny the younger
RE: Westinghouse circa 20's radio-so... they think im the guy to get this thing working - by Chas - 09-06-2021, 06:49 PM
Eico 232 VTVM Schematic
There are currently 6810 online users. [Complete List]
» 1 Member(s) | 6809 Guest(s)
