Philco model 54C
As Doug said, it's a pretty good set. I restored one for somebody a few years ago, and it really wasn't that difficult. I even rebuilt the electrolytic cans, to avoid cramming the underneath of the chassis any further with new electrolytics.
You want a difficult rebuild job? Try a 41-226. A packed chassis, with rubber-covered wiring galore. Ugh.
Philco model 54C - by 7estatdef - 04-18-2011, 04:31 PM
Re: Philco model 54C - by Doug Houston - 04-18-2011, 05:14 PM
Re: Philco model 54C - by 7estatdef - 04-18-2011, 06:09 PM
Re: Philco model 54C - by Ron Ramirez - 04-18-2011, 06:56 PM
Re: Philco model 54C - by 7estatdef - 04-18-2011, 07:38 PM
Re: Philco model 54C - by Ron Ramirez - 04-18-2011, 08:04 PM
There are currently 8809 online users. [Complete List]
» 1 Member(s) | 8808 Guest(s)
