Philco 38-690 restoration
1) It plays, but crackles.
Check any remaining capacitors that have not been replaced. Test the tubes.
2) Somebody replaced capacitors, so I mainly need to check that work, and finish replacing the electrolytics and a few otehrs.
There is one bakelite block under the upper chassis. Do not disturb that bakelite block! That does not contain a capacitor, but instead, it contains the coils of the 10 kc audio filter.
2) I see no sign of cleaning
One method of cleaning a chassis:
http://philcoradio.com/phorum/showthread.php?tid=1473
another method:
http://philcoradio.com/phorum/showthread.php?tid=1221
3) The various rubber parts (tuner mount, etc.) were not replaced.
Contact Ed (Blacksmith) for these:
http://www.renovatedradios.com/parts.html#rubber
4) The cabinet will need to be refinished.
I can't help you here, others will hopefully chime in.
5) The original dial lights were discarded, rather than rebult, so I will need them.
You can get these from any of the 1937-38 Philcos with the Automatic Tuning mechanism. It should not be too difficult to find these.
6) One tweeter cone is all broken-up, so I'll have it re-coned.
Before sending it out, read this:
http://www.philcoradio.com/phorum/showth...p?tid=1003
7) There is some strange added antenna wire, but connecting to the "red" terminal also works. I was able to receive a few stations on AM and on shortwave with a 10' piece of hookup wire.
On 1938 Philco models, the "red" terminal is the antenna terminal. I can't address the added antenna wire without knowing where it connects inside the chassis.
8 ) There is a strange two-conductor shielded cable with the two conductors connected and covered by old friction tape.
Is this connected to anything inside the radio chassis?
Philco 38-690 restoration - by FStephenMasek - 04-18-2011, 09:30 PM
RE: Philco 38-690 restoration - by FStephenMasek - 04-13-2013, 12:47 PM
RE: Philco 38-690 restoration - by FStephenMasek - 04-13-2013, 09:16 PM
RE: Philco 38-690 restoration - by morzh - 04-13-2013, 09:22 PM
RE: Philco 38-690 restoration - by FStephenMasek - 02-17-2014, 12:35 PM
RE: Philco 38-690 restoration - by morzh - 02-17-2014, 12:43 PM
RE: Philco 38-690 restoration - by FStephenMasek - 02-17-2014, 10:13 PM
RE: Philco 38-690 restoration - by morzh - 02-17-2014, 10:16 PM
RE: Philco 38-690 restoration - by FStephenMasek - 06-22-2014, 12:04 AM
RE: Philco 38-690 restoration - by morzh - 06-22-2014, 10:56 AM
RE: Philco 38-690 restoration - by FStephenMasek - 06-22-2014, 01:01 PM
RE: Philco 38-690 restoration - by FStephenMasek - 06-22-2014, 07:18 PM
RE: Philco 38-690 restoration - by morzh - 06-22-2014, 08:44 PM
RE: Philco 38-690 restoration - by gregb - 06-22-2014, 08:47 PM
RE: Philco 38-690 restoration - by PhilcoJohn - 06-23-2014, 05:47 PM
RE: Philco 38-690 restoration - by morzh - 06-23-2014, 05:53 PM
RE: Philco 38-690 restoration - by FStephenMasek - 07-06-2014, 01:40 PM
RE: Philco 38-690 restoration - by morzh - 07-06-2014, 02:13 PM
RE: Philco 38-690 restoration - by FStephenMasek - 07-06-2014, 02:46 PM
RE: Philco 38-690 restoration - by morzh - 07-06-2014, 02:51 PM
RE: Philco 38-690 restoration - by FStephenMasek - 07-10-2014, 04:32 PM
RE: Philco 38-690 restoration - by morzh - 07-10-2014, 05:32 PM
RE: Philco 38-690 restoration - by FStephenMasek - 11-06-2014, 01:27 AM
RE: Philco 38-690 restoration - by sam - 11-06-2014, 03:57 AM
RE: Philco 38-690 restoration - by 462ron - 11-06-2014, 01:13 PM
RE: Philco 38-690 restoration - by klondike98 - 11-06-2014, 02:08 PM
RE: Philco 38-690 restoration - by morzh - 11-06-2014, 02:35 PM
RE: Philco 38-690 restoration - by FStephenMasek - 11-11-2014, 12:57 PM
RE: Philco 38-690 restoration - by morzh - 11-11-2014, 01:17 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-19-2011, 10:07 AM
Re: Philco 38-690 restoration - by FStephenMasek - 04-19-2011, 12:59 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-19-2011, 02:00 PM
Re: Philco 38-690 restoration - by FStephenMasek - 04-19-2011, 02:35 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-19-2011, 02:47 PM
Re: Philco 38-690 restoration - by FStephenMasek - 04-20-2011, 10:47 PM
Re: Philco 38-690 restoration - by Ron Ramirez - 04-21-2011, 07:41 AM
Re: Philco 38-690 restoration - by FStephenMasek - 04-26-2011, 10:06 PM
There are currently 9674 online users. [Complete List]
» 1 Member(s) | 9673 Guest(s)
