Philco 20 dial lamp
That's the filter choke in the power supply #28. Have the caps inside the metal can on top of the chassis been replaced w/film caps? If not this can cause that choke some thermal discomfort.
I would suspect that choke should measure several hundred ohms but it does have that a cap in parallel with it. Cap could be shorted. If it's arcing back to the core you could try insulating it from the chassis.
https://philcoradio.com/library/images/schem/20a.jpg
Philco 20 dial lamp - by RTM - 09-18-2021, 06:17 AM
RE: Philco 20 dial lamp - by RTM - 09-22-2021, 08:14 PM
RE: Philco 20 dial lamp - by RTM - 09-22-2021, 09:25 PM
RE: Philco 20 dial lamp - by Radioroslyn - 09-22-2021, 09:27 PM
RE: Philco 20 dial lamp - by RTM - 09-23-2021, 02:12 PM
RE: Philco 20 dial lamp - by Radioroslyn - 09-23-2021, 03:09 PM
RE: Philco 20 dial lamp - by RTM - 09-23-2021, 03:33 PM
RE: Philco 20 dial lamp - by Radioroslyn - 09-23-2021, 05:47 PM
RE: Philco 20 dial lamp - by RTM - 09-24-2021, 11:55 AM
RE: Philco 20 dial lamp - by Radioroslyn - 09-24-2021, 01:41 PM
RE: Philco 20 dial lamp - by RTM - 09-29-2021, 09:54 PM
RE: Philco 20 dial lamp - by mikethedruid - 09-30-2021, 12:22 AM
RE: Philco 20 dial lamp - by RTM - 09-30-2021, 08:34 AM
RE: Philco 20 dial lamp - by RTM - 10-05-2021, 04:44 PM
RE: Philco 20 dial lamp - by RTM - 10-13-2021, 10:40 PM
RE: Philco 20 dial lamp - by Ron Ramirez - 10-14-2021, 03:59 PM
RE: Philco 20 dial lamp - by RTM - 10-30-2021, 05:07 AM
RE: Philco 20 dial lamp - by morzh - 10-30-2021, 06:21 PM
RE: Philco 20 - by GarySP - 09-18-2021, 10:23 AM
RE: Magnetic tuning question. - by RTM - 09-29-2021, 06:27 AM
91H Code 126 Restore
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4169 online users. [Complete List]
» 1 Member(s) | 4168 Guest(s)
