Grunow model 580 only tracking on half of tuning cap
Congratulations, Greg ! It's always nice when we figure out what is at the root of a problem. Good lesson from this. Assume nothing. As we go through the radio, check each piece we remove against the schematic. You are not the first to have found some odd things which looked original. Glad it all worked out.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 8651 online users. [Complete List]
» 2 Member(s) | 8649 Guest(s)
