Is this "real" or someone's fancy design?
reybo Wrote:
codefox1 Wrote:Does Abby Sciuto want it? Could be a perfect prop for the show. Just a thought. Wouldn't blend in with my yesteryear ketch.
NHOH so I looked Abby up on Wiki. Strange creature. Is that her twin who does commercials for a travel site?
Pauley Perrette is tasty.... That's a whole different subject though. I agree that would be something that would fit in with her "style".
Brian Mattson
Coon Rapids, MN
Re: Is this "real" or someone's fancy design? - by Beckett - 04-20-2011, 04:02 PM
There are currently 9850 online users. [Complete List]
» 2 Member(s) | 9848 Guest(s)
