Sony Pro-80
More fiddling this past weekend, and it looks as if there is a fault in the flex connection between the CPU and PLL/power board. This part is soldered in place, so the only option (if it can't be rescued) is to replace with fine hookup wire.
Bound and determined to fix this thing, but it is challenging me to a duel!
Sony Pro-80 - by EdHolland - 09-01-2021, 07:21 PM
RE: Sony Pro-80 - by Arran - 09-01-2021, 11:56 PM
RE: Sony Pro-80 - by BrendaAnnD - 09-02-2021, 12:14 AM
RE: Sony Pro-80 - by EdHolland - 09-02-2021, 12:05 PM
RE: Sony Pro-80 - by EdHolland - 09-13-2021, 02:51 PM
RE: Sony Pro-80 - by OZ4 - 09-13-2021, 04:42 PM
RE: Sony Pro-80 - by EdHolland - 09-13-2021, 08:30 PM
RE: Sony Pro-80 - by EdHolland - 09-18-2021, 09:42 PM
RE: Sony Pro-80 - by EdHolland - 09-27-2021, 09:22 PM
RE: Sony Pro-80 - by EdHolland - 09-28-2021, 01:17 PM
