Grundig 5399/u/s
Adding a bit to what Rod said -
I'd probably first check to see if the oscillator is doing its thing when on BC. To check the oscillator, I usually put another radio (on BC) nearby to "listen" for the oscillator as I tune the radio under test across the band.
If it's not oscillating, I'd check the band switch (dirty?), BC oscillator coil bad...
I suppose it could be something before that, like the antenna transformer/related band switch... But I might expect a tiny bit of signal to find its way to the mixer.
Greg O.
Whitehall, PA
Grundig 5399/u/s - by vecher - 10-07-2021, 01:24 PM
RE: Grundig 5399/u/s - by RodB - 10-07-2021, 02:56 PM
RE: Grundig 5399/u/s - by morzh - 10-07-2021, 08:21 PM
RE: Grundig 5399/u/s - by vecher - 10-08-2021, 12:18 AM
RE: Grundig 5399/u/s - by Greg - 10-08-2021, 12:21 PM
RE: Grundig 5399/u/s - by vecher - 10-10-2021, 05:11 PM
RE: Grundig 5399/u/s - by vecher - 10-11-2021, 09:48 AM
RE: Grundig 5399/u/s - by RodB - 10-11-2021, 12:13 PM
RE: Grundig 5399/u/s - by morzh - 10-11-2021, 05:55 PM
RE: Grundig 5399/u/s - by vecher - 10-11-2021, 11:40 PM
RE: Grundig 5399/u/s - by morzh - 10-12-2021, 12:09 AM
RE: Grundig 5399/u/s - by BrendaAnnD - 10-12-2021, 02:29 AM
RE: Grundig 5399/u/s - by Phlogiston - 10-12-2021, 01:10 PM
RE: Grundig 5399/u/s - by RodB - 10-12-2021, 02:16 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8490 online users. [Complete List]
» 3 Member(s) | 8487 Guest(s)
