Grundig 5399/u/s
In the German sets of the 50's, the two most problematic areas are the tuner module and it's associated tube, and the detector circuit, which is generally a 6T8 (can't remember the Euro tube equivalent number ATM)
Grundig 5399/u/s - by vecher - 10-07-2021, 01:24 PM
RE: Grundig 5399/u/s - by RodB - 10-07-2021, 02:56 PM
RE: Grundig 5399/u/s - by morzh - 10-07-2021, 08:21 PM
RE: Grundig 5399/u/s - by vecher - 10-08-2021, 12:18 AM
RE: Grundig 5399/u/s - by Greg - 10-08-2021, 12:21 PM
RE: Grundig 5399/u/s - by vecher - 10-10-2021, 05:11 PM
RE: Grundig 5399/u/s - by vecher - 10-11-2021, 09:48 AM
RE: Grundig 5399/u/s - by RodB - 10-11-2021, 12:13 PM
RE: Grundig 5399/u/s - by morzh - 10-11-2021, 05:55 PM
RE: Grundig 5399/u/s - by vecher - 10-11-2021, 11:40 PM
RE: Grundig 5399/u/s - by morzh - 10-12-2021, 12:09 AM
RE: Grundig 5399/u/s - by BrendaAnnD - 10-12-2021, 02:29 AM
RE: Grundig 5399/u/s - by Phlogiston - 10-12-2021, 01:10 PM
RE: Grundig 5399/u/s - by RodB - 10-12-2021, 02:16 PM
