1930 Model 77 Lowboy
Hi DubVNurse, and welcome.
May I suggest that, when you take photos, that you include at least one of the back of the radio, showing the tubes?
Also, please read the following before posting photos here - this link will give you complete instructions on adding photos to your posts.
http://www.philcoradio.com/phorum/showthread.php?tid=29
http://www.philcoradio.com/phorum/showth...p?tid=4371
1930 Model 77 Lowboy - by DubVNurse - 04-22-2011, 10:58 AM
Re: 1930 Model 77 Lowboy - by gary rabbitt - 04-23-2011, 12:32 AM
Re: 1930 Model 77 Lowboy - by Uffda - 04-23-2011, 09:49 AM
Re: 1930 Model 77 Lowboy - by DubVNurse - 04-23-2011, 10:54 AM
Re: 1930 Model 77 Lowboy - by Ron Ramirez - 04-23-2011, 11:15 AM
Re: 1930 Model 77 Lowboy - by Uffda - 04-23-2011, 03:13 PM
