Philco F-1740 Car Radio
here's a schematic for the L-1760. http://www.nostalgiaair.org/PagesByModel...014047.pdf
i have a schematic for the F-1740. they are similar but with different part numbers. and the L-1760 has two 7C5 audio amp tubes.
https://www.radiomuseum.org/r/philco_f1740.html#top isn't much help.
the outer winding on the lone oscillator transformer of older transitones frequently corrodes and is open. you might check the main osc coil [part no. 59 on the L-1760 schematic] for continuity. the antenna and RF transformers, too. and, i suppose all the other osc coils.
touch the tip of a soldering iron to the grid of the 7C5 audio tube. plug the iron in but leave it off. you should hear a hum if the audio stage is good.
you need to see the word "dial" in the left window to use the tuner.
Philco F-1740 Car Radio - by Gene Montgomery - 10-27-2021, 12:07 PM
RE: Philco F-1740 Car Radio - by David - 10-27-2021, 02:19 PM
RE: Philco F-1740 Car Radio - by fenbach - 10-27-2021, 11:04 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5142 online users. [Complete List]
» 1 Member(s) | 5141 Guest(s)
