Philco 200X question
Thanks Ron! I'm glad there is a photo of one in the gallery. I want to redo the finish on mine. One question? On the lower part of the 200x cabinet, is that black paint or a very dark toned laquer?
Philco 200X question - by 37silverstreak - 04-23-2011, 11:25 PM
Re: Philco 200X question - by Ron Ramirez - 04-24-2011, 07:38 AM
Re: Philco 200X question - by 37silverstreak - 04-24-2011, 08:31 PM
Re: Philco 200X question - by Ron Ramirez - 04-24-2011, 08:43 PM
Re: Philco 200X question - by Alan Douglas - 04-26-2011, 06:07 PM
Philco 91 Tuning Condenser
