Help with a model...
After finally having a chance to look a lot more closely at the radio, i found a sticker that has 39-6844E on it. Could that be the model #?
Help with a model... - by Guest - 03-01-2006, 05:45 PM
[No subject] - by Chuck Schwark - 03-01-2006, 07:36 PM
[No subject] - by 49Stude63 - 03-01-2006, 09:56 PM
[No subject] - by Chuck Schwark - 03-01-2006, 10:46 PM
[No subject] - by 49Stude63 - 03-02-2006, 03:38 PM
[No subject] - by Guest - 03-24-2006, 05:01 PM
[No subject] - by PTurney - 03-24-2006, 06:53 PM
[No subject] - by Guest - 04-11-2006, 03:08 PM
[No subject] - by Chuck Schwark - 04-11-2006, 07:01 PM
Philco 91 Tuning Condenser
There are currently 6664 online users. [Complete List]
» 2 Member(s) | 6662 Guest(s)
