Philco 643 restoration
Did you notice the date on that transformer? "11-39." It was made in November 1939, roughly four years after your 643 was built, so that transformer is a replacement unit. That would explain the crude soldering you mentioned.
Hmmm. Unusual...not unheard of for an audio output to fail that soon in a set's life, but unusual...
Philco 643 restoration - by Bob Andersen - 08-04-2011, 10:13 PM
Re: Philco 643 restoration - by Bob Andersen - 08-05-2011, 01:44 AM
Re: Philco 643 restoration - by Ron Ramirez - 08-05-2011, 06:38 AM
Re: Philco 643 restoration - by TA Forbes - 08-05-2011, 12:36 PM
Re: Philco 643 restoration - by Ron Ramirez - 08-05-2011, 12:59 PM
Re: Philco 643 restoration - by Bob Andersen - 08-05-2011, 07:28 PM
Re: Philco 643 restoration - by TA Forbes - 08-05-2011, 10:07 PM
Re: Philco 643 restoration - by Bob Andersen - 09-02-2011, 04:29 PM
Re: Philco 643 restoration - by TA Forbes - 09-02-2011, 11:39 PM
Re: Philco 643 restoration - by Ron Ramirez - 09-02-2011, 11:43 PM
Re: Philco 643 restoration - by Bob Andersen - 09-03-2011, 12:30 AM
Re: Philco 643 restoration - by Ron Ramirez - 09-03-2011, 07:59 AM
Re: Philco 643 restoration - by 7estatdef - 09-03-2011, 11:44 AM
Re: Philco 643 restoration - by Arran - 09-05-2011, 01:24 AM
Re: Philco 643 restoration - by Bob Andersen - 09-07-2011, 11:11 PM
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
