Philco BC Resistor Wattage
Hi Ken and Welcome to the phourm.
I would think a 25w unit should work fine.
Philco BC Resistor Wattage - by Ken Kidd - 04-27-2011, 09:51 AM
Re: Philco BC Resistor Wattage - by 7estatdef - 04-27-2011, 04:32 PM
Re: Philco BC Resistor Wattage - by Ken Kidd - 04-27-2011, 07:13 PM
Re: Philco BC Resistor Wattage - by 7estatdef - 04-27-2011, 09:13 PM
The speaker table error?
Philco 70 antenna lead
