Philco BC Resistor Wattage
Thanks Terry for the info. Don't think I have that high a wattage in my parts for the ohms I need. Can get it at work. Ken
Philco BC Resistor Wattage - by Ken Kidd - 04-27-2011, 09:51 AM
Re: Philco BC Resistor Wattage - by 7estatdef - 04-27-2011, 04:32 PM
Re: Philco BC Resistor Wattage - by Ken Kidd - 04-27-2011, 07:13 PM
Re: Philco BC Resistor Wattage - by 7estatdef - 04-27-2011, 09:13 PM
The speaker table error?
Philco 70 antenna lead
