46-200 Antenna glue?
Don't know if you can still get it (Duco), cause of them darn crazy kids sniff the darn stuff. Just did a quick search and you can get it on line.
The diagram is here: http://www.nostalgiaair.org/Resources/591/M0013591.htm
Had one of those little set years ago. Cute little guy and play well!
46-200 Antenna glue? - by Olden Broak - 04-27-2011, 06:47 PM
Re: 46-200 Antenna glue? - by 7estatdef - 04-27-2011, 06:54 PM
Re: 46-200 Antenna glue? - by Olden Broak - 04-27-2011, 08:24 PM
Re: 46-200 Antenna glue? - by 7estatdef - 04-27-2011, 09:11 PM
Re: 46-200 Antenna glue? - by Olden Broak - 04-28-2011, 10:25 AM
Re: 46-200 Antenna glue? - by 7estatdef - 04-28-2011, 08:08 PM
Re: 46-200 Antenna glue? - by Olden Broak - 04-28-2011, 09:26 PM
Re: 46-200 Antenna glue? - by 7estatdef - 04-29-2011, 08:48 AM
Re: 46-200 Antenna glue? - by Olden Broak - 04-29-2011, 10:15 PM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 12:27 AM
Re: 46-200 Antenna glue? - by 7estatdef - 05-01-2011, 07:36 AM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 04:53 PM
Re: 46-200 Antenna glue? - by 7estatdef - 05-01-2011, 05:57 PM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 06:25 PM
Re: 46-200 Antenna glue? - by 7estatdef - 05-01-2011, 08:08 PM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 08:44 PM
The speaker table error?
Philco 70 antenna lead
