Philco 20 Cap Values
When using larger cap vale in the rectifier filter (the very first cap after the rectifier tube) you will end up with higher rectified voltage. This might make tubes run hotter.
Other caps (after the choke) are indeed not as important.
20A used higher values to compensate for 25Hz. But give it 50Hz and the average voltage goes up.
Philco 20 Cap Values - by wabr101 - 11-16-2021, 08:45 PM
RE: Philco 20 Cap Values - by mikethedruid - 11-16-2021, 11:50 PM
RE: Philco 20 Cap Values - by morzh - 11-16-2021, 11:56 PM
RE: Philco 20 Cap Values - by Steve Davis - 11-17-2021, 10:27 AM
91H Code 126 Restore
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4602 online users. [Complete List]
» 1 Member(s) | 4601 Guest(s)
