RESTORATION IN GENERAL
Hello,
Thanks. He was really confused about the subject of the painting. I did not know that they did it with hairspray.
One thing: H2SO4 is sulfuric acid. You mean HCL, hydrochloric acid ?
RESTORATION IN GENERAL - by ducretet - 11-16-2021, 06:21 AM
RE: RESTORATION IN GENERAL - by Phlogiston - 11-16-2021, 11:54 AM
RE: RESTORATION IN GENERAL - by ducretet - 11-16-2021, 12:09 PM
RE: RESTORATION IN GENERAL - by klondike98 - 11-16-2021, 01:13 PM
RE: RESTORATION IN GENERAL - by Phlogiston - 11-16-2021, 02:36 PM
RE: RESTORATION IN GENERAL - by RodB - 11-16-2021, 03:28 PM
RE: RESTORATION IN GENERAL - by ducretet - 11-16-2021, 03:53 PM
RE: RESTORATION IN GENERAL - by John Bartley - 11-16-2021, 04:19 PM
RE: RESTORATION IN GENERAL - by ducretet - 11-17-2021, 02:37 AM
RE: RESTORATION IN GENERAL - by ducretet - 11-17-2021, 06:05 AM
RE: RESTORATION IN GENERAL - by radiorich - 11-17-2021, 08:54 AM
RE: RESTORATION IN GENERAL - by morzh - 11-17-2021, 03:01 PM
RE: RESTORATION IN GENERAL - by ducretet - 11-17-2021, 03:50 PM
RE: RESTORATION IN GENERAL - by ducretet - 11-17-2021, 03:55 PM
RE: RESTORATION IN GENERAL - by Phlogiston - 11-17-2021, 07:54 PM
RE: RESTORATION IN GENERAL - by Phlogiston - 11-19-2021, 01:24 AM
RE: RESTORATION IN GENERAL - by Phlogiston - 11-20-2021, 02:59 PM
Eico 232 VTVM Schematic
There are currently 9263 online users. [Complete List]
» 2 Member(s) | 9261 Guest(s)
