Model 60 troubles
Would check the grid wire on the 75 to see if there is a short where it goes thru the chassis. Low plate voltage on the 75  will cause it. If all the voltage are good I would recheck the wiring of the replaced parts. Are all of the blocks wired correctly inside and out? I've miswired the coupling caps before and had the same results. GL.
Model 60 troubles - by Cu879 - 11-17-2021, 04:32 PM
RE: Model 60 troubles - by Radioroslyn - 11-17-2021, 09:28 PM
RE: Model 60 troubles - by Cu879 - 11-17-2021, 11:48 PM
91H Code 126 Restore
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4605 online users. [Complete List]
» 1 Member(s) | 4604 Guest(s)
