Is this worth restoration?
Unless you are good (and fast) at all of the aspects of restoration, then fixing it up will be a loosing proposition - but if you like to work for low wages - you still might loose out since buyers want either original or a near perfect restoration. Even a semi-good job may be harder to sell than as-is.
Parting it out might bring more money. It really depends how many people can drive to your location. Shipping will eat all of your profit.
Good luck
Let us know what you decide.
Russ (who is not in the market for more consoles - oh, yes, there is also that. Table radios are far easier to sell.)
Is this worth restoration? - by stephjab - 11-18-2021, 10:49 AM
RE: Is this worth restoration? - by klondike98 - 11-18-2021, 01:09 PM
RE: Is this worth restoration? - by Phlogiston - 11-18-2021, 02:46 PM
RE: Is this worth restoration? - by mikethedruid - 11-18-2021, 03:44 PM
RE: Is this worth restoration? - by morzh - 11-18-2021, 09:57 PM
RE: Is this worth restoration? - by stephjab - 11-20-2021, 10:29 AM
RE: Is this worth restoration? - by Phlogiston - 11-20-2021, 12:11 PM
RE: Is this worth restoration? - by klondike98 - 11-20-2021, 02:59 PM
RE: Is this worth restoration? - by morzh - 11-20-2021, 09:19 PM
RE: Is this worth restoration? - by stephjab - 11-21-2021, 11:37 AM
RE: Is this worth restoration? - by Ron Ramirez - 11-21-2021, 01:45 PM
RE: Is this worth restoration? - by Arran - 12-04-2021, 05:16 AM
RE: Is this worth restoration? - by GarySP - 12-04-2021, 11:24 AM
