Newby with tube question on a 37-116
John
Thanks for the advice. I am inclined to use the 6H6G with a shield as it is period correct.
Chris
Newby with tube question on a 37-116 - by qanerd - 06-20-2011, 11:57 PM
Re: Newby with tube question on a 37-116 - by qanerd - 06-21-2011, 04:25 PM
The speaker table error?
Philco 70 antenna lead
