38-8 high voltage problem
i have checked to amps at # 12 13K 5 wt resistor and it read 10.56 ma so that seems OK maybe that resistor just gets warmer because its 5wt er,,,it still get a little distorted after its been on for 5 min or so still checking out the speaker is proving a bear it has a HS style speaker and you can't just put a pm in its place looking for a way to put a pm with out blowing up the radio
thank again for all the help
the old geezer
john
38-8 high voltage problem - by jstaf40 - 06-10-2011, 04:07 PM
Re: 38-8 high voltage problem - by codefox1 - 06-10-2011, 06:15 PM
Re: 38-8 high voltage problem - by jstaf40 - 06-21-2011, 04:31 PM
Re: 38-8 high voltage problem - by codefox1 - 06-21-2011, 11:39 PM
The speaker table error?
Philco 70 antenna lead
