Philco Tropic 3212-121
Thank you for this information. The search option on this site didn't find any results; I see that I should have searched the archives manually.
I will post some photos once I clean this set up and determine the way ahead. The tuner is frozen and, unfortunately, someone in the past removed the 6V power supply and substituted a multi-tap power transformer and selenium rectifier. I've some work ahead of me.
Cheers,
Scott
Philco Tropic 3212-121 - by HooiserScootrer - 11-22-2021, 05:03 PM
RE: Philco Tropic 3212-121 - by Radioroslyn - 11-22-2021, 06:05 PM
RE: Philco Tropic 3212-121 - by klondike98 - 11-22-2021, 07:03 PM
RE: Philco Tropic 3212-121 - by HooiserScootrer - 11-23-2021, 09:47 AM
RE: Philco Tropic 3212-121 - by klondike98 - 11-25-2021, 12:12 AM
RE: Philco Tropic 3212-121 - by HooiserScootrer - 11-28-2021, 02:42 PM
RE: Philco Tropic 3212-121 - by klondike98 - 11-28-2021, 02:49 PM
Eico 232 VTVM Schematic
