Philco PT-25 tube layout
Hi Gary & Welcome!
I see this is your first time here. Great bunch if you need help or info for your Philco.
Here's the diagram for your PT-25 It's actually for the TH-4 but should be the same or pretty close. http://www.nostalgiaair.org/Resources/241/M0014241.htm
Gud lk w/it
Terry N3GTE
Philco PT-25 tube layout - by k4gns - 04-28-2011, 08:36 AM
Re: Philco PT-25 tube layout - by Ron Ramirez - 04-28-2011, 11:50 AM
Re: Philco PT-25 tube layout - by k4gns - 04-28-2011, 01:03 PM
Re: Philco PT-25 tube layout - by 7estatdef - 04-28-2011, 08:36 PM
