Threads: 54
If the hammer had not worked I was going to suggest using a hydraulic jack under something solid to press it out, such as the main beam of the house, or a truck frame. The prior option would have involved using a wooden post on top, with a jack under it, a socket or stub of pipe under the jack, the speaker rear bracket, and a pair of blocks at the bottom, or one block with a hole drilled in the center.
RE: Philco 90 restoration - by Arran - 11-28-2021, 08:33 AM
Users browsing this thread: 42 Guest(s)
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM |
91H Code 126 Restore
I'm pretty sure that the dotted line I circled in an earlier post signifies that it is applicable to the 226 model which...RealRider — 08:05 AM |
Philco 49-1040
Hello bob,
that underside looks like it is all original !
Sincerely Richardradiorich — 02:07 AM |
Philco 49-1040
Oh yes, many bumblebees and loktal tubes.
The cutout is for the speaker. Here's a photo from a different set.
Bob Andersen — 12:59 AM |
Philco 49-1040
Bob;
Looks like another "Bumble Bee" special, like my Brand Z T.O radios. Is that section they took out of ...Arran — 12:19 AM |
Philco 49-1040
Hello Bob,
You are like the home for lost tv's like how people bring pets home !
Sincerely Richardradiorich — 12:00 AM |
Philco 49-1040
I thought I had an arrangement to restore this set for a customer but his wife said heck no. Instead, he gave it to me....Bob Andersen — 10:29 PM |
I kept working on reassembly this week. I wasn’t able to solder for a few days while it was too cold (single digit low t...jrblasde — 09:27 PM |
Well, powering it up would be too good to be true, and I had that feeling.
Before I did, I decided to check the coils...morzh — 06:02 PM |
Thanks Chas,
sure will give it a look!morzh — 03:39 PM |
There are currently 4605 online users. [Complete List] » 3 Member(s) | 4602 Guest(s)
