Philco 47-1230 restoration
Thanks Keith.
Those are a lot smaller than what I tough bakelite blocks would be.
I'll give another look specifically for that next time I open the radio (still waiting for correct lug strips to replace the electrolytic caps)
but I don't think there's any bakelite blocks in the 47-1230. At least, the line filter caps seems to be mica caps, not bakelited paper caps.
I'll post if I find anything, at least for the purpose of helping the next guy working on a 47-1230... threads like this helped me start when I first got my radio!
-Mars
Philco 47-1230 restoration - by robertwsimpson - 02-11-2011, 09:09 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-11-2011, 02:14 PM
Re: Philco 47-1230 restoration - by TA Forbes - 02-11-2011, 02:37 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-11-2011, 11:11 PM
Re: Philco 47-1230 restoration - by marcapra - 02-12-2011, 12:16 AM
Re: Philco 47-1230 restoration - by Jayce - 02-12-2011, 02:05 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-12-2011, 09:31 PM
Re: Philco 47-1230 restoration - by DeckApe - 02-14-2011, 11:04 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-15-2011, 09:08 PM
Re: Philco 47-1230 restoration - by codefox1 - 02-18-2011, 06:01 PM
Re: Philco 47-1230 restoration - by codefox1 - 02-21-2011, 01:37 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 01:37 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:27 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:34 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 11:32 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 11:58 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-23-2011, 10:32 AM
Re: Philco 47-1230 restoration - by ipwizard - 04-28-2011, 06:08 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 09:54 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-29-2011, 04:07 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 05:58 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-30-2011, 01:22 AM
Re: Philco 47-1230 restoration - by Marsupial - 04-30-2011, 11:45 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 12:03 AM
Re: Philco 47-1230 restoration - by Marsupial - 05-01-2011, 12:48 AM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-01-2011, 07:54 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 10:55 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-05-2011, 09:04 AM
Philco 91 Tuning Condenser
