I confused on model 38-12 resistors
For a nickel apiece I'd just replace them.
I confused on model 38-12 resistors - by Art Hoch - 04-29-2011, 03:10 PM
Re: I confused on model 38-12 resistors - by codefox1 - 04-29-2011, 03:23 PM
The speaker table error?
Philco 70 antenna lead
