46-200 Antenna glue?
Thanks, I think I'll put this one back in a box for now and
try to finish the five other radios I have on the bench.
Rob
46-200 Antenna glue? - by Olden Broak - 04-27-2011, 06:47 PM
Re: 46-200 Antenna glue? - by 7estatdef - 04-27-2011, 06:54 PM
Re: 46-200 Antenna glue? - by Olden Broak - 04-27-2011, 08:24 PM
Re: 46-200 Antenna glue? - by 7estatdef - 04-27-2011, 09:11 PM
Re: 46-200 Antenna glue? - by Olden Broak - 04-28-2011, 10:25 AM
Re: 46-200 Antenna glue? - by 7estatdef - 04-28-2011, 08:08 PM
Re: 46-200 Antenna glue? - by Olden Broak - 04-28-2011, 09:26 PM
Re: 46-200 Antenna glue? - by 7estatdef - 04-29-2011, 08:48 AM
Re: 46-200 Antenna glue? - by Olden Broak - 04-29-2011, 10:15 PM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 12:27 AM
Re: 46-200 Antenna glue? - by 7estatdef - 05-01-2011, 07:36 AM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 04:53 PM
Re: 46-200 Antenna glue? - by 7estatdef - 05-01-2011, 05:57 PM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 06:25 PM
Re: 46-200 Antenna glue? - by 7estatdef - 05-01-2011, 08:08 PM
Re: 46-200 Antenna glue? - by Olden Broak - 05-01-2011, 08:44 PM
The speaker table error?
Philco 70 antenna lead
