Philco H-16 and H-26 field coils
Yes, I noticed early on that cap. 59 was drawn backwards. It was replaced with a 10mf@25V axial, positive to ground, underneath the chassis. The HV CT is connected to the neg. of 59A and 57 then to resistor 58.
I'm about ready to start subbing parts that couldn't cause this, like the output tranny.
Ed
Philco H-16 and H-26 field coils - by Ed Locker - 04-05-2006, 08:31 AM
[No subject] - by Chuck Schwark - 04-05-2006, 08:39 AM
[No subject] - by Chuck Schwark - 04-05-2006, 07:31 PM
[No subject] - by Ed Locker - 04-05-2006, 07:40 PM
[No subject] - by Chuck Schwark - 04-05-2006, 08:14 PM
[No subject] - by Ed Locker - 04-16-2006, 04:37 PM
[No subject] - by Chuck Schwark - 04-16-2006, 05:18 PM
[No subject] - by Ed Locker - 04-17-2006, 08:33 AM
[No subject] - by Ed Locker - 04-26-2006, 10:10 PM
