38-690 Code 125
Ok, now we know that the oscillator is running at the right frequency and agrees with the dial calibration, so the dial error must be caused by the IF not being tuned to 470 kc.
I don't think anything is physically wrong with the IF, only that the IF transformers are tuned to the wrong frequency. The compression trimmer caps in the IF cans have a large tuning range, so they are easy to set to a freq other than 470 kc.
Somehow your generator is off freq or there is some other reason the IF is different from 470 kc. You can try the suggested idea to check the second harmonic of your 470 kc generator signal by listening with your digital receiver at 940 kc.
Another thing to try is to gradually tune the IF transformers toward the correct 470 kc by tuning in a known freq broadcast station, setting the dial to where it is actually received, not where it should be. Then tune slightly toward the correct dial calibration and repeak the IF transformers on the received signal. Repeat this procedure in steps until the station is received at the proper indication on the dial. Since you know your oscillator frequency is correct, this should align your IF to very close to 470 kc. If you can't reach proper dial calibration by this method then something is really wrong with the IF transformers or circuitry.
38-690 Code 125 - by RGK20m3 - 11-24-2021, 08:26 PM
RE: 38-690 Code 125 - by klondike98 - 11-24-2021, 09:01 PM
RE: 38-690 Code 125 - by RGK20m3 - 11-26-2021, 05:41 PM
RE: 38-690 Code 125 - by klondike98 - 11-26-2021, 06:21 PM
RE: 38-690 Code 125 - by RGK20m3 - 11-26-2021, 10:29 PM
RE: 38-690 Code 125 - by RGK20m3 - 12-02-2021, 07:35 PM
RE: 38-690 Code 125 - by morzh - 12-02-2021, 08:09 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-02-2021, 08:58 PM
RE: 38-690 Code 125 - by morzh - 12-02-2021, 09:02 PM
RE: 38-690 Code 125 - by radiorich - 12-02-2021, 10:01 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-02-2021, 11:41 PM
RGK20m3 - by RGK20m3 - 12-05-2021, 06:03 PM
RE: 38-690 Code 125 - by David - 12-05-2021, 07:19 PM
RE: 38-690 Code 125 - by klondike98 - 12-09-2021, 08:08 PM
RGK20m3 - by RGK20m3 - 12-10-2021, 02:54 PM
RE: 38-690 Code 125 - by Mondial - 12-10-2021, 06:42 PM
RE: 38-690 Code 125 - by RGK20m3 - 12-10-2021, 07:15 PM
RE: 38-690 Code 125 - by morzh - 12-10-2021, 07:27 PM
RE: 38-690 Code 125 - by Mondial - 12-10-2021, 07:40 PM
RE: 38-690 Code 125 - by mikethedruid - 12-10-2021, 08:01 PM
RGK20m3 - by RGK20m3 - 12-10-2021, 10:09 PM
RGK20m3 - by RGK20m3 - 12-11-2021, 12:14 PM
RE: 38-690 Code 125 - by Mondial - 12-11-2021, 01:58 PM
RGK20m3 - by RGK20m3 - 12-11-2021, 05:41 PM
RE: 38-690 Code 125 - by Mondial - 12-11-2021, 06:48 PM
RE: 38-690 Code 125 - by tbone - 12-12-2021, 02:27 PM
RGK20m3 - by RGK20m3 - 12-13-2021, 08:24 PM
RE: 38-690 Code 125 - by Mondial - 12-14-2021, 10:22 AM
RE: 38-690 Code 125 - by morzh - 12-14-2021, 12:40 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-14-2021, 01:40 PM
RE: 38-690 Code 125 - by RGK20m3 - 12-14-2021, 03:25 PM
RE: 38-690 Code 125 - by morzh - 12-14-2021, 03:35 PM
RE: 38-690 Code 125 - by Mondial - 12-14-2021, 04:06 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-14-2021, 04:42 PM
RGK20m3 - by RGK20m3 - 12-14-2021, 10:32 PM
RE: 38-690 Code 125 - by Ron Ramirez - 12-14-2021, 10:58 PM
RGK20m3 - by RGK20m3 - 12-15-2021, 09:01 AM
RGK20m3 - by RGK20m3 - 12-15-2021, 11:55 AM
RE: 38-690 Code 125 - by Mondial - 12-15-2021, 03:02 PM
RGK20m3 - by RGK20m3 - 12-15-2021, 05:14 PM
RE: 38-690 Code 125 - by RGK20m3 - 01-02-2022, 06:05 PM
RE: 38-690 Code 125 - by Greg - 01-02-2022, 06:42 PM
RE: 38-690 Code 125 - by Mondial - 01-02-2022, 07:59 PM
RGK20m3 - by RGK20m3 - 01-03-2022, 12:36 PM
RE: 38-690 Code 125 - by Mondial - 01-03-2022, 01:43 PM
RGK20m3 - by RGK20m3 - 01-04-2022, 09:12 AM
RE: 38-690 Code 125 - by Mondial - 01-04-2022, 12:21 PM
RE: 38-690 Code 125 - by RGK20m3 - 01-04-2022, 07:01 PM
RGK20m3 - by RGK20m3 - 01-05-2022, 12:36 PM
RE: 38-690 Code 125 - by Mondial - 01-05-2022, 01:56 PM
RGK20m3 - by RGK20m3 - 01-05-2022, 02:57 PM
RE: 38-690 Code 125 - by Mondial - 01-05-2022, 05:59 PM
RGK20m3 - by RGK20m3 - 01-06-2022, 07:39 PM
RE: 38-690 Code 125 - by Mondial - 01-07-2022, 11:44 AM
RE: 38-690 Code 125 - by RGK20m3 - 01-07-2022, 01:03 PM
RGK20m3 - by RGK20m3 - 01-07-2022, 01:32 PM
RE: 38-690 Code 125 - by Mondial - 01-07-2022, 01:49 PM
RGK20m3 - by RGK20m3 - 01-07-2022, 02:31 PM
RGK20m3 - by RGK20m3 - 01-29-2022, 01:25 PM
RE: 38-690 Code 125 - by Brad Winder - 02-02-2022, 08:30 PM
RGK20m3 - by RGK20m3 - 02-04-2022, 07:41 PM
RE: 38-690 Code 125 - by Brad Winder - 02-06-2022, 02:53 PM
RE: 38-690 Code 125 - by RGK20m3 - 02-07-2022, 11:26 AM
38-690 RF Alignment - by RGK20m3 - 12-09-2021, 02:54 PM
RE: 38-690 RF Alignment - by morzh - 12-09-2021, 04:16 PM
RE: 38-690 RF Alignment - by RGK20m3 - 12-09-2021, 04:40 PM
Users browsing this thread: 19 Guest(s)
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 5541 online users. [Complete List]
» 1 Member(s) | 5540 Guest(s)
