Philco 47-1230 restoration
It makes good sense. So the best would be to purchase .01 300V safety Y2 caps?
Any place I can get those, aside digikey? (how do we find them... are they stated "Y2 safety cap, .01, 300V"?)
-Mars
Philco 47-1230 restoration - by robertwsimpson - 02-11-2011, 09:09 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-11-2011, 02:14 PM
Re: Philco 47-1230 restoration - by TA Forbes - 02-11-2011, 02:37 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-11-2011, 11:11 PM
Re: Philco 47-1230 restoration - by marcapra - 02-12-2011, 12:16 AM
Re: Philco 47-1230 restoration - by Jayce - 02-12-2011, 02:05 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-12-2011, 09:31 PM
Re: Philco 47-1230 restoration - by DeckApe - 02-14-2011, 11:04 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-15-2011, 09:08 PM
Re: Philco 47-1230 restoration - by codefox1 - 02-18-2011, 06:01 PM
Re: Philco 47-1230 restoration - by codefox1 - 02-21-2011, 01:37 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 01:37 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:27 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:34 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 11:32 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 11:58 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-23-2011, 10:32 AM
Re: Philco 47-1230 restoration - by ipwizard - 04-28-2011, 06:08 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 09:54 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-29-2011, 04:07 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 05:58 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-30-2011, 01:22 AM
Re: Philco 47-1230 restoration - by Marsupial - 04-30-2011, 11:45 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 12:03 AM
Re: Philco 47-1230 restoration - by Marsupial - 05-01-2011, 12:48 AM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-01-2011, 07:54 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 10:55 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-05-2011, 09:04 AM
Philco 91 Tuning Condenser
There are currently 9642 online users. [Complete List]
» 1 Member(s) | 9641 Guest(s)
