philco 42-350,355
Not going to be pirates on that old band. Could be baby monitors or more likely intermodulation from strong local FM stations mixing with various other signals.
Also, the old FM band was not NB, the transmissions specs, disregarding frequency, were exactly the same as the current band.
philco 42-350,355 - by falcon123 - 12-19-2021, 01:29 AM
RE: philco 42-350,355 - by morzh - 12-19-2021, 10:09 AM
RE: philco 42-350,355 - by Ron Ramirez - 12-19-2021, 10:57 AM
RE: philco 42-350,355 - by Paul Philco322 - 12-19-2021, 11:11 AM
RE: philco 42-350,355 - by RodB - 12-19-2021, 11:28 AM
RE: philco 42-350,355 - by BrendaAnnD - 12-19-2021, 11:55 AM
RE: philco 42-350,355 - by Paul Philco322 - 12-19-2021, 12:11 PM
RE: philco 42-350,355 - by Brad Winder - 12-19-2021, 12:17 PM
RE: philco 42-350,355 - by Paul Philco322 - 12-19-2021, 12:19 PM
RE: philco 42-350,355 - by morzh - 12-19-2021, 12:39 PM
RE: philco 42-350,355 - by RodB - 12-19-2021, 02:19 PM
Eico 232 VTVM Schematic
There are currently 9260 online users. [Complete List]
» 2 Member(s) | 9258 Guest(s)
