Condenser Question
Negative should go to the pin 6 on the 6U7G, positive to transformer 4 terminal where the big 15K is connected.
There should be a wire from the pin 6 on the 6U7G to another terminal on transformer 4 so effectively the cap is connected across two terminals of transformer 4
Condenser Question - by Masonparker - 12-15-2021, 08:08 PM
RE: Condenser Question - by morzh - 12-15-2021, 08:13 PM
RE: Condenser Question - by Masonparker - 12-15-2021, 08:16 PM
RE: Condenser Question - by Masonparker - 12-15-2021, 08:22 PM
RE: Condenser Question - by morzh - 12-15-2021, 08:33 PM
RE: Condenser Question - by morzh - 12-15-2021, 09:40 PM
RE: Condenser Question - by Masonparker - 12-15-2021, 09:50 PM
RE: Condenser Question - by RodB - 12-15-2021, 09:59 PM
RE: Condenser Question - by morzh - 12-15-2021, 10:01 PM
RE: Condenser Question - by Masonparker - 12-16-2021, 12:30 PM
RE: Condenser Question - by Radioroslyn - 12-16-2021, 12:37 PM
RE: Condenser Question - by Dan Walker - 12-17-2021, 11:34 PM
RE: Condenser Question - by RodB - 12-18-2021, 10:33 AM
RE: Condenser Question - by Masonparker - 12-18-2021, 09:42 PM
RE: Condenser Question - by radiorich - 12-19-2021, 02:03 AM
RE: Condenser Question - by RodB - 12-19-2021, 10:50 AM
RE: Condenser Question - by RodB - 12-19-2021, 11:40 AM
RE: Condenser Question - by Mondial - 12-19-2021, 01:23 PM
RE: Condenser Question - by RodB - 12-19-2021, 02:38 PM
RE: Condenser Question - by Masonparker - 12-21-2021, 03:44 AM
RE: Condenser Question - by Masonparker - 12-21-2021, 03:57 AM
RE: Condenser Question - by Masonparker - 12-21-2021, 04:04 AM
RE: Condenser Question - by Mondial - 12-21-2021, 10:11 AM
RE: Condenser Question - by Masonparker - 12-25-2021, 07:03 PM
RE: Condenser Question - by morzh - 12-25-2021, 07:18 PM
RE: Condenser Question - by Masonparker - 12-26-2021, 09:37 AM
RE: Condenser Question - by Mondial - 12-26-2021, 09:45 AM
RE: Condenser Question - by Masonparker - 12-26-2021, 08:15 PM
RE: Condenser Question - by Masonparker - 12-28-2021, 07:40 PM
RE: Condenser Question - by morzh - 12-28-2021, 08:02 PM
