Philco 70 If transformer question
Keep in mind that in 1931, the typical voltmeters used to make the voltage measurements at the factory had an input impedance of 1000 ohms/volt, which loads down the circuit under test and produces false readings. Only they did not know this at the time.
In other words, voltage readings taken under identical conditions today (110 or 115 volts AC input, depending upon published specs) with a DMM or a good VTVM will be higher than Philco's published voltage readings.
Philco 70 If transformer question - by radio1 - 12-16-2021, 07:29 PM
RE: Philco 70 If transformer question - by morzh - 12-16-2021, 07:51 PM
RE: Philco 70 If transformer question - by radio1 - 12-16-2021, 07:52 PM
RE: Philco 70 If transformer question - by radio1 - 12-21-2021, 08:45 PM
RE: Philco 70 If transformer question - by radio1 - 12-25-2021, 07:53 PM
RE: Philco 70 If transformer question - by Ron Ramirez - 12-25-2021, 08:04 PM
RE: Philco 70 If transformer question - by radio1 - 12-25-2021, 08:34 PM
RE: Philco 70 If transformer question - by radio1 - 12-31-2021, 09:31 PM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 5524 online users. [Complete List]
» 2 Member(s) | 5522 Guest(s)
