Pushbutton tuning problem
I have restored a Philco model 41-296. The circuitry in this radio is very similar to several Philcos made in 1940 and 1941. It has seven tuned circuit pushbuttons.
The radio works perfectly in all respects but one. Although the three lowest frequency pushbuttons are clearly labeled as tunable down to 540 kHz, I can't get any of them to go lower than about 640 kHz. They all exhibit this same problem.
The ceramic trimmer capacitors associated with these buttons are antenna trimmers only and have very little effect on the tuned frequency. They have a great effect on how well a station comes in after tuning it in.
It appears that, in pushbutton mode only, the local oscillator just won't tune low enough. Any suggestions are most welcome.
Pushbutton tuning problem - by Guest - 04-19-2006, 10:12 AM
[No subject] - by Terry Judkins - 04-19-2006, 11:27 AM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 6441 online users. [Complete List]
» 1 Member(s) | 6440 Guest(s)
