Adding FM to a Philco 118
I bought a couple of the "David Winter" FM modules     FM Converter for vintage radios (paleophonies.com)     to experiment with. I'm going to install the first one in a Philco 118.
[Image: https://live.staticflickr.com/65535/5178...744b_c.jpg]FM Conversion Module by Steve Davis, on Flickr
I have been using this 118 chassis with no cabinet in my shop for many years, it just sits on a shelf with an H-13 speaker.
[Image: https://live.staticflickr.com/65535/5178...fcb3_c.jpg]Philco 118 Chassis by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5178...8c9e_c.jpg]FM Conversion by Steve Davis, on Flickr
The first step has been completed, replacing the electrolytics with film capacitors. I had restored the chassis several years ago, it still works well. The past few years, I have been using film caps to replace electrolytics so, I decided to do that upgrade.
This is a four section 1uf 1uf 1uf 2uf. Since this cap is clamped from the top, I cut that end (done previously). A piece of 1" PVC pipe fits the inside of the can snuggly and is used to hold the cap on the can. I am using "orange dip" film caps.
[Image: https://live.staticflickr.com/65535/5178...3454_c.jpg]Philco 118 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5178...f9fa_c.jpg]Philco 118 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5178...4fda_c.jpg]Philco 118 by Steve Davis, on Flickr
The main filter caps were done a little differently. I cut the bottom ends off and made nylon plugs to replace them.
[Image: https://live.staticflickr.com/65535/5178...aa36_c.jpg]Philco 118 by Steve Davis, on Flickr
Heat shrink tubing was used to insulate the connections from the can.
[Image: https://live.staticflickr.com/65535/5178...fc8b_c.jpg]Philco 118 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5178...f3f7_c.jpg]Philco 118 by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5178...34b6_c.jpg]Philco 118 by Steve Davis, on Flickr
I want to use the band switch for switching the FM so, this will require a new switch with more poles and 3 positions. Coming next.
M R Radios   C M Tubes
Adding FM to a Philco 118 - by Steve Davis - 12-30-2021, 12:15 AM
RE: Adding FM to a Philco 118 - by morzh - 12-30-2021, 12:44 AM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-30-2021, 01:04 AM
RE: Adding FM to a Philco 118 - by Arran - 12-30-2021, 04:16 AM
RE: Adding FM to a Philco 118 - by GarySP - 12-30-2021, 08:35 AM
RE: Adding FM to a Philco 118 - by willydcamaro - 12-30-2021, 02:26 PM
RE: Adding FM to a Philco 118 - by Radioroslyn - 12-30-2021, 03:16 PM
RE: Adding FM to a Philco 118 - by Ron Ramirez - 12-30-2021, 08:03 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-30-2021, 10:55 PM
RE: Adding FM to a Philco 118 - by radiorich - 12-30-2021, 11:55 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-31-2021, 08:35 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 12-31-2021, 09:52 PM
RE: Adding FM to a Philco 118 - by radiorich - 01-01-2022, 12:19 AM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-03-2022, 09:56 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-04-2022, 12:46 PM
RE: Adding FM to a Philco 118 - by radiorich - 01-04-2022, 02:54 PM
RE: Adding FM to a Philco 118 - by exray - 01-06-2022, 05:31 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-06-2022, 08:20 PM
RE: Adding FM to a Philco 118 - by exray - 01-06-2022, 09:08 PM
RE: Adding FM to a Philco 118 - by Paul Philco322 - 01-06-2022, 10:06 PM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-07-2022, 12:08 AM
RE: Adding FM to a Philco 118 - by radiorich - 01-07-2022, 01:11 AM
RE: Adding FM to a Philco 118 - by exray - 01-07-2022, 08:48 AM
RE: Adding FM to a Philco 118 - by radiorich - 01-07-2022, 09:10 AM
RE: Adding FM to a Philco 118 - by exray - 01-07-2022, 10:10 AM
RE: Adding FM to a Philco 118 - by Steve Davis - 01-07-2022, 10:23 AM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
There are currently 4273 online users. [Complete List]
» 2 Member(s) | 4271 Guest(s)
